Almost have a new job...Need Tech advice
Post new topic   This topic is locked: you cannot edit posts or make replies.     |##| -> |=|     MC MCSE Certification Forums -> Windows 2000/XP/2003
Nighthawk
Needs Serious Help
Needs Serious Help
Post subject: Almost have a new job...Need Tech advice
Posted: Thu Jan 26, 2006 3:18 pm
I have been asked back for a second interview for a job that seems really great.
They said they need someone to improve upon password security for files and troubleshoot e-mail. I was wondering if any of you can give me advice on the best and easiest ways to do this for them. They run XP and 2000. Most of them use Outlook. All responses are appreciated. Thanks.
A+
Network+
MCP Windows XP
Offline View user's profile Send private message
Foxynox
Friend of MC MCSE
Friend of MC MCSE
Posted: Fri Jan 27, 2006 2:42 am
Hey, what kind of position have you been offered?
Is a large company?
Foxynox
MCSA:Messaging, MCSE 2000, 2003
MVP: Windows Server (Setup/Deployment) 2004, 2005, 2006
www.mcmcse.com/contributors/gibson.shtml
Offline View user's profile Send private message Send e-mail MSN Messenger
Nighthawk
Needs Serious Help
Needs Serious Help
Posted: Fri Jan 27, 2006 10:42 am
It's not a very large company. It's a Help Desk job. They haven't offered it yet. I have a 2nd interview.
A+
Network+
MCP Windows XP
Nighthawk
Needs Serious Help
Needs Serious Help
Posted: Fri Jan 27, 2006 6:14 pm
Does anyone have any advice?
A+
Network+
MCP Windows XP
Marathonman
Head Moderator
Head Moderator
Posted: Fri Jan 27, 2006 6:43 pm
Ya sit down and learn every little setting that Outlook has and how to use it.
Whether you think that you can, or that you can't, you are usually right
A+, Network+, MCP, MCSA, CNA,
Offline View user's profile Send private message Visit poster's website
Nighthawk
Needs Serious Help
Needs Serious Help
Posted: Fri Jan 27, 2006 6:54 pm
Thanks, I know Outlook really well already. What else?
A+
Network+
MCP Windows XP
Headhunter
Moderator
Moderator
Posted: Sat Jan 28, 2006 2:42 pm
Withdraw your application....
Koen
CCSI #30501 CCNP CCIP CCVP CCSP CCDP Cisco Advanced Wireless LAN Field Specialist Cisco Unity Design Specialist Cisco IP Telephony Design Specialist JNCIS-ES JNCIA-ER JNCIA-EX MCSE MCSA:Messaging
Nighthawk
Needs Serious Help
Needs Serious Help
Posted: Sun Jan 29, 2006 8:24 pm
Headhunter, you are a real wiseguy.
A+
Network+
MCP Windows XP
peccavi
Posted: Mon Jan 30, 2006 3:52 am
Hi all,
Review file systems (especially NTFS) and file/folder permissions. It's really huge topic.
Rage Against Machine!
itdaddy
Permanent Fixture
Permanent Fixture
Post subject: Email Troubleshooting
Posted: Mon Jan 30, 2006 4:48 pm
headhunter you belong in CCIE section right? this place
is too beneath you. we spell wrong and are not as good as you
just face it...........
anyways, about your email troubleshooting.
I would say make sure email server path is correct when users have issues, and just know the MS Outlook software is a plus. most users
don't really have a clue how to make a signature block, find their archive folder.. Make sure their archive folders are saved toa safe place. we have it where i work(yes headhunter i actually have an IT job!) we point their archive folders to their user folder and save it in a folder called Email Archive. Understand Exhange server and how it plays a part in MS Outlook client interface. www.trainsignal has great CBTs on Exhange Server and get and MS Outlook CBT. tell them you are good at document
problems and you keep track of trends in problem solving. They are most interested in your ability to solve problems. YOur A+ speaks loud. Just
answer them in a waythat convinces them you can solve issues and you have yoru resources to do so. Good luck man!
itdaddy Wink
IT DADDY
A+, MCP, CCNA
Asst Network Admin, Credit Union
WIP:MCSE, BSCS grad 2010....
kidvelvet
Moderator
Moderator
Posted: Tue Jan 31, 2006 5:36 am
Helpdesk is all about troubleshooting. Each company or software helpdesk has their own set of tools, software, OS, etc. When hiring for a helpdesk, they aren't worried that you know how to fix or run Super Duper Application with Retsin. All they care about is that you know how to do basic troubleshooting, and they will probably ask some technical questions, but most likely will have you do non-technical troubleshooting as well. For example, one help desk job wanted me to figure out why someone's lamp kept turning off every day at 8pm...things like that.
Go in with what you know, troubleshoot the problems they give you to the best of your ability, and when you don't know the answer to something, don't try to BS your way out of it...be straight up and say that you don't know. If you are right for the job, you will get it. And remember, it may not always be your technical side...it could be that you get a job because you are a good fit with the team as well.
Good luck!
kidvelvet
www.kidvelvet.net
Yes, your problem is the most important. Just like everybody else's.
Nighthawk
Needs Serious Help
Needs Serious Help
Posted: Wed Feb 08, 2006 5:24 pm
Thanks to all for their help. I am still looking for a job but am confident.
A+
Network+
MCP Windows XP
Post new topic   This topic is locked: you cannot edit posts or make replies.     |##| -> |=|     MC MCSE Certification Forums -> Windows 2000/XP/2003 All times are GMT - 5 Hours
