| View previous topic :: View next topic |
| Author |
Message |
sepehr Becoming a Regular
Post subject: I CLick It DOes Not Go! Posted: Tue Sep 27, 2005 6:56 am |
Help others: Review your books and training products here |
i bet that you have faced this problem before!
sometimes when i click a program to run it be id doesn't run!i dont know why i just keep on cliking but no function! i had run the program before ! but now i cant!why is that and what shoud i do?
( i reinstalled the program and restart the pc too)
any ideas? |
| Back to top |
jsprague Site Admin
Joined: 18 Sep 2001 Posts: 7870 Location: Portland, Or
Post subject: Posted: Tue Sep 27, 2005 8:16 am |
Which program? Which operating system? Does anything ever happen if you wait a while? _________________ Did you know?
Buying discount exam vouchers saves you money and helps support this site. |
| Back to top |
Post subject: Posted: Tue Sep 27, 2005 9:45 am |
| jsprague wrote: | | Which program? Which operating system? Does anything ever happen if you wait a while? |
I am using winxp pro media center edition but i have seen this in win xp pro s p2 too!
and the programs are easyboot and alchoal120%
but i think it is not related to the specified program because the former times that i had this problem it was about another program (i guess it was my photoshop)
no nothing happens when i execute it!
now any ideas how can i get rid off this problem? |
| Back to top |
Foxynox Friend of MC MCSE
Joined: 15 Dec 2002 Posts: 1219 Location: Oxford - UK
Post subject: Posted: Tue Sep 27, 2005 11:22 am |
Does it make any difference if you Right click the icon and select Open?
Does it behave the same for every program? If so I would look at the Mouse properties in control panel for double click speed. _________________ Foxynox
MCSA:Messaging, MCSE 2000, 2003
MVP: Windows Server (Setup/Deployment) 2004, 2005, 2006
www.mcmcse.com/contributors/gibson.shtml |
| Back to top |
avon1982 Moderator
Post subject: Posted: Tue Sep 27, 2005 11:43 am |
Do you get an application hang error in the event viewer which could because the program and the associated dll module stopped responding
under such circumstances if click the application multiple times then it will open multiple instances of the application which will not help the situation
Also do you face this situation immediatelyafter the application hangs also does the problem persists after a restart Is this random issue has the application permenantely stopped responding |
| Back to top |
Post subject: Posted: Tue Sep 27, 2005 12:57 pm |
| avon1982 wrote: | Do you get an application hang error in the event viewer which could because the program and the associated dll module stopped responding
first i should say that i tried opening the file by rightclicking and selecting open! and i know my mouse is configured properly!
then about the event viewer! i deleted all events then executed the file that i had problem with but nothing logged into event viewer(i refreshed the event viewer too) and i have this problem with just 2 of my applications!
and another thing when i first installed those applications they were working fine for 2 days after i installed windows but now they do not execute!
any other ideas friends? |
| Back to top |
Post subject: Posted: Wed Sep 28, 2005 2:10 am |
Both of these software types work with your CD and DVD. Are there any issues with your hardware? ie CD Drive or DVD ROM?
Do you have any virtual CD/DVD drives set up that could be upsetting the software?
If you are not getting any answers fast, I would contact both the manufactures own support desks. They are more likely to find a solution quickly. _________________ Foxynox
| Back to top |
Post subject: Posted: Wed Sep 28, 2005 6:21 am |
this issue is not related to manfacturer because the program used to work fine! and two programs wont have same problem! this is a problem related to windows i guess! (because as i told you i had this problem with photoshop before)
and about virtual drives !yeah i installed 1 virtual as i installed alchohal120%
but i do not run programs with tha drive!
Hey You Masters GIve Some Ideas PLease!  |
| Back to top |
Post subject: thats getting intersting Posted: Wed Sep 28, 2005 7:12 am |
this problem has happened to my dap (Download Accelarator) DOwnload manager too!
thats so awfull  |
| Back to top |
jsprague Site Admin
Post subject: Posted: Wed Sep 28, 2005 6:07 pm |
I guess its possible that your Windows installation is messed up. You could try repairing it with the installation CD. _________________ Did you know?
| Back to top |
Post subject: Posted: Thu Sep 29, 2005 5:17 am |
| yeah you know i wanted to know if i could do something beside repairing but as you say it seems i have to do this! |
| Back to top |
LawrenceA Becoming a Regular
Joined: 30 Sep 2004 Posts: 66 Location: Parksville B.C. Canada
Post subject: Posted: Thu Sep 29, 2005 8:51 pm |
Have you tried something really simple like creating a new shortcut to the program? _________________ A+, Network+ |
| Back to top |
Post subject: Posted: Fri Sep 30, 2005 3:33 am |
| yeah i did made another instances of progam and i still have the problem! |
| Back to top |
ricka182 Needs Serious Help
Joined: 22 Mar 2003 Posts: 1566 Location: 42.50.21 71.20.27
Post subject: Posted: Fri Sep 30, 2005 8:46 am |
I would try SFC /scannow, for file integrity, or you could just reinstall the OS. _________________ i remain, he who remains to be....
MCDST, A+, Network+, (210, 215), CST, CNST, DCSE |
| Back to top |
