Switchport Security
Post new topic   Reply to topic     |##| -> |=|     MC MCSE Certification Forums -> CCENT/CCNA
fjohnson
Becoming a Regular
Becoming a Regular
Post subject: Switchport Security
Posted: Wed Dec 01, 2010 12:42 pm
This question is in regards to mac-address sticky.
I thought the purpose of the sticky command was to be used when you have a device plugged into the port to capture the mac-address so you don't have to manually enter the mac-address? If it is, then I am doing something wrong.
#interface fa0/1
#switchport mode access
#switchport port-security
#switchport port-security mac-address sticky
#switchport port-security maximum 1
#switchport port-security violation shutdown
FJohnson
A+, Network+, MCSE 2000.
soon CCNA.
Offline View user's profile Send private message
Headhunter
Moderator
Moderator
Posted: Wed Dec 01, 2010 2:35 pm
is there a mac address in the sh run?
Koen
CCSI #30501 CCNP CCIP CCVP CCSP CCDP Cisco Advanced Wireless LAN Field Specialist Cisco Unity Design Specialist Cisco IP Telephony Design Specialist JNCIS-ES JNCIA-ER JNCIA-EX MCSE MCSA:Messaging
Offline View user's profile Send private message Visit poster's website
kidvelvet
Moderator
Moderator
Posted: Wed Dec 01, 2010 9:04 pm
Sticky keeps the mac address in the running config, and if a wr mem is performed, it will be there when there is a reboot. As HH said, is there a mac address in the running config?
kidvelvet
www.kidvelvet.net
Yes, your problem is the most important. Just like everybody else's.
fjohnson
Becoming a Regular
Becoming a Regular
Posted: Thu Dec 02, 2010 3:08 pm
No. I didn't put a mac address in, I was just doing a lab with two laptops and noticed when I connected them I had to always manually configure the mac-address.
FJohnson
soon CCNA.
Headhunter
Moderator
Moderator
Posted: Thu Dec 02, 2010 4:10 pm
sim or real switch?
Koen
fjohnson
Becoming a Regular
Becoming a Regular
Posted: Thu Dec 02, 2010 9:36 pm
first tried it with the sim, but no part of the commands would work. Then tried it with my live rack, everything worked except for the sticky, where I had to input the mac-address manually.
basically if I had 12 workstations plugged in it would be hard to run to each machine and input each mac-address.
FJohnson
soon CCNA.
Headhunter
Moderator
Moderator
Posted: Fri Dec 03, 2010 1:32 am
change maximum to 2
and do sh run
on the live rack
Koen
fjohnson
Becoming a Regular
Becoming a Regular
Posted: Fri Dec 03, 2010 12:54 pm
May I ask why 2? what I have read was that if you have the machines plugged in and then you put in the sticky command it captures that specific mac-address and stores it so no other device can connect.
FJohnson
soon CCNA.
Headhunter
Moderator
Moderator
Posted: Fri Dec 03, 2010 2:26 pm
bug, we use 3 for phone and pc or it doesn't work
Koen
fjohnson
Becoming a Regular
Becoming a Regular
Posted: Fri Dec 03, 2010 7:42 pm
It worked. Ok so I had the devices unplugged then I set the maximum to 2 and input the other commands. I then plugged in two separate devices and did the "show run" and saw the mac-address in the config. I then swapped the devices to test it and sure enough it worked.
So I guess that is the answer to my question. You have to have the devices unplugged before you do the commands.
FJohnson
soon CCNA.
fjohnson
Becoming a Regular
Becoming a Regular
Posted: Fri Dec 03, 2010 8:14 pm
Ok did some more testing and this time I did maximum 1 and configured the ports with the devices plugged in and SUCCESS.
Thank you
FJohnson
soon CCNA.
Post new topic   Reply to topic     |##| -> |=|     MC MCSE Certification Forums -> CCENT/CCNA All times are GMT - 5 Hours
