Post subject: WAN question Posted: Thu Nov 18, 2010 10:47 am
Which of the following describes the roles of devices in a WAN? (Choose three.)
A. A CSU/DSU terminates a digital local loop.
B. A modem terminates a digital local loop.
C. A CSU/DSU terminates an analog local loop.
D. A modem terminates an analog local loop.
E. A router is commonly considered a DTE device.
F. A router is commonly considered a DCE device.
I want to see what the answer is, I don't understand the modem and the csu/dsu part. _________________ FJohnson
A+, Network+, MCSE 2000.
soon CCNA.
The answer is A, D, E.
A: A CSU/DSU terminates a digital local loop.
A CSU/DSU is used for example to connect a customer to a T1 line (digital line). They can look like a modem or be built into a WAN card in a router. The DTE device (usually a router) connects to the CSU/DSU. So a CSU/DSU terminates a digital line.
An example of this is a dial up connection. The modem converts data to an acceptable form to go over the phone line (analog). The modem terminates the analog line. _________________ A+
Net+
CCENT
CCNA
I guess that "D" is the one I don't understand. In my studies it says that "A Modem converts digital signal to Analog, Then back again". _________________ FJohnson
soon CCNA.
Ok, think of it this way.
---Computer -- Switch -- Modem -- Analog line
--- digital --- digital -- digital - analog -- analog
When traffic is coming back from the internet it is in analog form when it's going over the analog line, when it gets to the modem the modem will convert it back to digital.
So a modem does "converts digital signal to Analog, Then back again. BUT at the same time it's the termination of the analog local loop. _________________ A+
Net+
CCENT
CCNA
