CCNA recertification
Post new topic   Reply to topic     |##| -> |=|     MC MCSE Certification Forums -> CCENT/CCNA
MrCraig
Becoming a Regular
Becoming a Regular
Post subject: CCNA recertification
Posted: Thu Jun 17, 2010 1:22 am
Hello folks,
I am a year away from the CCNA expiration date, and while there is still plenty of time, I started looking at the recertification and narrowed things down to 3 options:
1. ICND2.
Advantages:
* Cheap
* Easy (no new material to learn beyond what is already learned)
Disadvantages:
*No progress in certification
2. CCNA concentration
Advantages:
* Additional certificate
* Medium amount of learning (as it's still NA level)
Disadvantages:
* More expensive than the other options
* Staying at CCNA level
3. One of the CCNP exams
Advantages:
* Climbing "up" on the "certification ladder"
* Cheap
Disadvantages:
* More efforts required
* Triggers the CCNP timer (3 years to complete)
* (this one is specific to me) Risk of starting it too early and becoming paper CCNP as I deal with Cisco equipment on a rather basic level at the moment
So I am wondering...
Re #2: Do CCNA concentrations (particularly CCNA: Security and CCNA: Service Provider) hold any value at all? Is having "CCNA, CCNA: SP" on the resume any better than just "CCNA"?
Re #3: How unwise is it to start CCNP track at this point? I have ~5 years of experience in system administration + 2 years of tech.support prior to that, plus a degree in CS, network administration. Primary duties are on server support side of things with little exposure to advanced networking. I have not yet decided whether to focus on a particular area, and what it would be - I'm choosing between networking, virtualization, and security...
Your opinions and suggestions on the matter are greatly appreciated.
Offline View user's profile Send private message
horndog
Certification Addict
Posted: Thu Jun 17, 2010 7:42 am
You can only answer that question.
Is the CCNP the route you want to take you should probably research the requirements and see if that is the route.
MCP# 1031105
MCSE Windows 2003
MCSA Windows 2003
MCP Windows NT 4.0 Workstation
MCTS: 70-640
MCTS: 70-642
MCTS: 70-643
MrCraig
Becoming a Regular
Becoming a Regular
Posted: Fri Jun 18, 2010 2:02 am
The decision which route to take afterall, yes. But I was hoping to get opinions on (a) CCNA concentrations and (b) whether the timing is good for me to start CCNP...
Headhunter
Moderator
Moderator
Posted: Fri Jun 18, 2010 2:35 am
SP is nice to have if you work with the ONS's but if you aren't working for a service provider then..... better off with voice or security
And at the end of the day it is your decision.... and having a specialization on CCNA is still more then CCNA.
Koen
CCSI #30501 CCNP CCIP CCVP CCSP CCDP Cisco Advanced Wireless LAN Field Specialist Cisco Unity Design Specialist Cisco IP Telephony Design Specialist JNCIS-ES JNCIA-ER JNCIA-EX MCSE MCSA:Messaging
Offline View user's profile Send private message Visit poster's website
MrCraig
Becoming a Regular
Becoming a Regular
Posted: Fri Jun 18, 2010 3:28 am
Thanks, that's the kind of comment I wanted to hear... So according to you, there is some recognition of specializations out there on the job market, that's good to know
MrCraig
Becoming a Regular
Becoming a Regular
Posted: Fri Jun 18, 2010 3:38 am
Btw, I've done the research on CCNP prior to posting, so I have a good idea about the certfication itself. It's just that reading discussions like this one leads to doubt and hesitation...
horndog
Posted: Fri Jun 18, 2010 2:10 pm
Do you have a specialization you would like to stick with? Voice, wireless, security, R&S, etc?
You could get re-certified and get CCNA+ one of the above.
Then once that is done, continue to go down that path.
MCP# 1031105
MCSE Windows 2003
MCSA Windows 2003
MCTS: 70-640
MCTS: 70-642
MCTS: 70-643
MrCraig
Becoming a Regular
Becoming a Regular
Posted: Fri Jun 18, 2010 2:54 pm
As said in the initial post, security, SP, and possibly, R&S look appealing to me, but none of them have yet been chosen as a career focus.
Yes, I know I could
MrCraig
Becoming a Regular
Becoming a Regular
Posted: Sat Jun 19, 2010 9:50 pm
To bring a closure to this topic, let me say that I have decided not to pursue CCNP at this point, until (and if ever) my career focus will start shifting towards network engineering.
As for CCNA renewal, as per HeadHunter's suggestion, I will go for CCNA:S, as a more versatile (comparing to CCNA:SPO) specialization.
Thanks for the comments guys!
horndog
Posted: Tue Jun 22, 2010 8:53 am
Doesn't it seem to be the hardest question to answer is which path and which certification?
It is a harder question if you are not 100% than any test question you will ever see.
MCP# 1031105
MCSE Windows 2003
MCSA Windows 2003
MCTS: 70-640
MCTS: 70-642
MCTS: 70-643
kidvelvet
Moderator
Moderator
Posted: Fri Jul 23, 2010 9:14 pm
The first thought that came to my head was this:
What are you doing currently?
It would make sense to follow a path that can either be paid for by your current employer. If you currently use your CCNA in your job and you plan on going forward with networking as a career, then I would go CCNP and get the boss to pay. If you are using the CCNA as a way to round out your knowledge in systems administration or engineering (in other words, you work mainly with servers), then I would just recert the CCNA with a current CCNA. I would not do voice or security unless either your current role uses it or you really want to simply learn for learning's sake. And there is nothing wrong with that.
Does that help at all?
kidvelvet
www.kidvelvet.net
Yes, your problem is the most important. Just like everybody else's.
MrCraig
Becoming a Regular
Becoming a Regular
Posted: Sun Jul 25, 2010 3:17 am
Yes, quite certainly, thank you.
If you are using the CCNA as a way to round out your knowledge in systems administration or engineering (in other words, you work mainly with servers)...
This is exactly my case. I support the company's computer system from A to Z, including servers and network. The network structure is very simple and little reconfiguration is ever needed for the 2-3 Cisco routers, so my job is mostly focused on taking care of the 30-40 VMware/Windows/Citrix/Linux servers and other sysadmin stuff (DNS, mail routing, traffic monitoring)...
And I kind of already settled on not pursuing CCNP at this point. Next spring or summer (CCNA is due for recerting in the fall '11) I am planning to go for CCNA:Security.
Cheers!
Post new topic   Reply to topic     |##| -> |=|     MC MCSE Certification Forums -> CCENT/CCNA All times are GMT - 5 Hours
