Spanned Volume & Striped Set
Post new topic   This topic is locked: you cannot edit posts or make replies.     |##| -> |=|     MC MCSE Certification Forums -> Server Exams
virtualwolf
Post subject: Spanned Volume & Striped Set
Posted: Sat Mar 03, 2007 10:46 pm
Can anyone tell me what the difference is between a Spanned Volume and a Striped Set?
Thanks
A+, Network+, MCP (Win2k Pro)
Offline View user's profile Send private message MSN Messenger
Twilight
Becoming a Regular
Becoming a Regular
Posted: Sun Mar 04, 2007 3:34 am
A spanned volume extends a single volume across a number of disks - but it's linear. Ie - it writes data to the first disk, when that's full it writes to the second disk, then to the third or fourth disks - if it's spanned over a number of disks. It's flexible because you can add disks to the span quite easily. There's no performance benefit to it.
A striped volume writes 1/2 of each file to each disk. The benefit is that it's a lot quicker in some situations as each physical disk only gets 1/2 the data to write.
If you stripe across 5 disks then a 1mb file writes 200k to each disk.
HTH
virtualwolf
Posted: Sun Mar 04, 2007 10:01 am
Thanks Twilight...I would assume that neither one is fault tolerant, right?
Twilight
Becoming a Regular
Becoming a Regular
Posted: Mon Mar 05, 2007 5:33 am
yep. no fault tolerance on either. You don't see spanned volumes in production much - except for JBOD. Striped sets are pretty common when speed is an issue but resilience isn't.
These things come up in exams sometimes and is just generally good to understand - what kind of data is appropriate on what kind of volume. Generally logs are good on striped sets as they can be write-intensive and it's not the end of the world if you lose them, but real data should be a on fault-tolerant drive.
Skull
Permanent Fixture
Permanent Fixture
Posted: Mon Mar 05, 2007 8:03 am
...However, one scenario commonly seen in production is the use of a fault tolerant striped set (called RAID 10), meaning that you create a striped set on, say 5 drives, and then you mirror it... In this case, what could easily become an issue is the disk drive cost... Shy
Phil
MCP
Machines should work. People should think!
Offline View user's profile Send private message Yahoo Messenger
thegreengorilla
Becoming a Regular
Becoming a Regular
Posted: Mon Mar 05, 2007 8:19 am
wouldn't raid 5 be another example?
visualicon2002
Permanent Fixture
Permanent Fixture
Posted: Mon Mar 05, 2007 9:44 am
3 or more Disks in a Striped set would classify as a RAID 5 and That sounds like a RAID 5 to me.
Josh
A+,Network+,CCNA (Expired),MCSA 2000,DCSE
Comptia IT Pro Member 07
Working on: 70-270,71-680 Windows 7 beta
Offline View user's profile Send private message Yahoo Messenger MSN Messenger
Skull
Permanent Fixture
Permanent Fixture
Posted: Mon Mar 05, 2007 10:17 am
[quote="visualicon2002]3 or more Disks in a Striped set would classify as a RAID 5 and That sounds like a RAID 5 to me.[/quote]
3 disks would of course be elligible for a RAID 5, but keep in mind that you still lose one drive's space, meaning there is really no fault-tolerancy here if you are to face a disk problem later.
My above suggestion (RAID 50), if you want both fault-tolerant and fast disk writing capabilities, works with a minimum of 4 drives (two, being the minimum for a striped set, and the other two for mirroring the set).
Phil
MCP
visualicon2002
Permanent Fixture
Permanent Fixture
Posted: Mon Mar 05, 2007 5:54 pm
Hmmm I see what you are talking about now.I did some research on RAID,thoese are Called Nested RAIDs (RAID 10,RAID 50) I had no idea.
Intresting.....
Josh
virtualwolf
Posted: Thu Mar 08, 2007 1:58 am
Actually they go over RAID 1+0 and RAID 0+1 in the Server+ Exam Cram book. I thought it sounded pretty cool myself....
Post new topic   This topic is locked: you cannot edit posts or make replies.     |##| -> |=|     MC MCSE Certification Forums -> Server Exams All times are GMT - 5 Hours
