Unable to share files after joining a Domain ???
Post new topic   This topic is locked: you cannot edit posts or make replies.     |##| -> |=|     MC MCSE Certification Forums -> Microsoft General
zadreamer
Post subject: Unable to share files after joining a Domain ???
Posted: Fri Nov 17, 2006 7:09 am
hi guys Razz
how are you all i'm very happy being here Rolling Eyes
i'v installed Windows Server 2003 and join about 6 xp workstations to that Server...
how ever no user on the workstations now can share any file there is no sharing and security tab when right click on a Folder to share it, also there is no sharing tab when selecting properties for the folder ??
i tried to check the use simple file sharing check box from the folder option also i tried to unckeck it but no thing work Confused
Note : i'v installed file server on the server is that the reason Confused
is there is a group policy that prevent the users from sharing files ??
please help Embarassed
thank you very much Laughing
Networking
Offline View user's profile Send private message
themanwhowouldbeking
Needs Serious Help
Needs Serious Help
Posted: Fri Nov 17, 2006 7:49 am
Is the user account you are logged on as at least a member of the local Power Users security group?
MCSA 2000/2003
MCP 210, 215, 216, 218, 290, 291, 293, 294
Current: 297
2O LEGEND
Offline View user's profile Send private message AIM Address Yahoo Messenger MSN Messenger
zadreamer
Posted: Fri Nov 17, 2006 1:39 pm
there is no Power users group in the Domain Embarassed
I searched for the power users group but i didn't find it Confused? Question
Networking
MCSE_Newbie
Needs Serious Help
Needs Serious Help
Posted: Fri Nov 17, 2006 3:49 pm
What happens when they try?
zadreamer
Posted: Fri Nov 17, 2006 4:33 pm
users can't share any file!!!
there is no sharing and security tab when right click on a Folder to share it, also there is no sharing tab when selecting properties for the folder...
I just can't share any file in any xp workstation PC...
Networking
kujayhawk93
Permanent Fixture
Permanent Fixture
Posted: Fri Nov 17, 2006 5:02 pm
Power Users is a local group on the XP workstation, not on the domain. You need to look under Local Users and Groups in Computer Management. I believe only members of the local Administrators group and Power Users can create new shares.
A+, Network+, MCP (70-270, 70-290), working on 70-291
avon1982
Moderator
Moderator
Posted: Sun Nov 19, 2006 11:02 am
Log on to the windows xp workstation with "administrative account " then enable the "simple file sharing " feature once you enable this the security
tab will not be available then log on using the user account then you will be able to see the "sharing tab"
MCSE 2003
zadreamer
Posted: Mon Nov 20, 2006 12:54 am
I'v fixec it thank you very much guys Very Happy
kujayhawk93 way works thank you Laughing
I added the domain users to the local power users group and, I find the sharing and security tab ...
but i had to go to every user computer to log on as administrator and add the domain user to the local power users group is there is a way to do that by a group policy or some thing like that Confused
thank you very much again Cool
Networking
Needs Serious Help
Needs Serious Help
Posted: Mon Nov 20, 2006 4:10 am
You can do this be creating a Restricted Groups group policy object.
1) You need to create a domain security group (for example, Local Power Users) and add all users to this security group or if you require all members of the Domain Users security group to be members of the local power users group you can use this security group within the group policy object.
2) Create a group policy object or add the group policy settings to an existing one.Browse to the following group policy object setting:
Computer Configuration>Windows Settings>Restricted Groups
3) Select 'Add Group', you will be prompted to add a group name, here you add 'Power Users' the reference to the local power users security group.
4) Enter the security group (or the Domain Users) created in Stage 1 to the 'Members of this group'.
5) Link the group policy object to the organisational unit(s) in which youre computer objects are located as the group policy object applys computer settings.
6) The group policy settings will be applied next time the machine policy is refreshed and rebooted as the settings are applied at startup.
It was me who first suggested checking the local power users security group, but never mind! Very Happy
MCSA 2000/2003
Current: 297
2O LEGEND
zadreamer
Posted: Mon Nov 20, 2006 12:53 pm
thank you very much themanwhowouldbeking I'll try this tomorrow when i go to work Very Happy
I'm so sorry i didn't notice that thanx to you and every one helped you guys very helpful:shy:
Networking
Needs Serious Help
Needs Serious Help
Posted: Mon Nov 20, 2006 3:44 pm
Only joking!
MCSA 2000/2003
Current: 297
2O LEGEND
Post new topic   This topic is locked: you cannot edit posts or make replies.     |##| -> |=|     MC MCSE Certification Forums -> Microsoft General All times are GMT - 5 Hours
